Ifffffffff you have a good heavy duty adequate high CCA battery ?? fully charged,,, perfect low resistance cables grounds and connections ??,,,a good low resistance starter switch/solenoid ??,,,,,,,but still slow cranking,, it could be the fault of the starter motor or for whatever reason ?? the engine is just hard to crank.. That being said having owned countless 6 volt cars trucks n tractors over 50 years, they were in general NOT known to be super fast crankers lolGot the new (heavy) ground cable and an oversize tractor battery in the car but it is slow cranking. Apparently that is just a characteristic of an automatic transmission equipped car on six volts.
John T
