60 clutch and skip
Hello,
When I first crank up the 60 it really runs good at a idle, but if you give it some rpm it runs ruff until it has worked for a while (it takes about 20-30 minutes then it really hits on both cylinders not missing a beat. Any suggestions what can be done would be very greatful.
While pulling the disc the clutch seems to begin slipping, tractor speed slows. It seems that the clutch needs adjusting, Can someone tell me where to start on adjusting.
If more information needed about either problem I would try to give all that I know, just don't know what else is needed to evaluate issues at this time. Thanks for all in put on these matters. Tommy in SC
1st order of advice is get a Manual, look here in the archives and NEVER Force any bolt you don't know anything about..!!
Those 3 clutch-adjusting bolts in particular..
Don't Force them, or you WILL break the Clutch Drum..
Adjust them with the Clutch engaged, to get them equally adjusted..Use penetrating oil, if needed....
Sounds like it is warming up..??
I think that NO "TWO" 2-Cylinder tractors run the same or have the same manors...!!!
They all have their own personallity...!
Ron.
