60 LP Exh. Manifoild
It should work just fine. The aftermarket manifolds are listed to fit 60, 620, 630, so a stock manifold should also fit all three. I guess I could look it up in the parts book to double check, but 99% sure that's right. Mike
Mike I was looking a Stiener Parts book and I drawed the same conclusion . thanks for the come back Gman
It will work. It may even give you a little power boost. If you live in a cold climate it's possible that you will have an icing problem and less than satisfactory operation when temperatures are chilly. Try it to see how you like it. It may pose no problem at all.
