There is a little vent hole on the front(to inside) plate that sometimes a bee will plug and if it is plugged the converter can"t breath and won"t turn loose any fuel. The hole is about 1/8 pipe and it"s off to one side of center, if it"s plugged becareful not to puncture the diaphram unplugging it. And if it"s not plugged with the switch on you can take a small hose and blow in that hole and you should be able to hear the air cleaner girgle
THE HOLE IS CLEAR. BUT IT STILL SEAMS ITS NOT GETTING GAS. AFTER IT HITS IT TAKES A MIN. BEFORE IT HITS AGAIN. ANY MORE IDEAS?
