60 MFWD build pics
tim s
Here are a few build pics of the 60 MFWD..for those that have not seen them...
WOW!!!--Nice Job--If I would have tried that it would have turned half or twice as fast as it should have and the wrong way--NICE welds too---Tee
No creations...I'm near done with fixing up a Deere 750C dozer,,it only has 1600 hours on it but has sat in the weeds in Alabama for over 15 years,,it had some rust issues, paint was faded badly AC wasn't working,,and I built a nice 12 ft root rake for it out of an old V-ripper,,I'm looking at the water pump seeping now,,,,not a pleasant place to get to,,,I will post some pics after bit,,,it is turning out nice.....Oh and I plan on getting the 6 way blade on the 60C this spring..
Sir, I must say you are extremely talented at machining parts! That is fantastic! Please post progress pictures as you can. Thank you for sharing this with us. Kow Farmer Kurt
You had a dream and you followed it threw, Awesome work ! There's a 70JD, i thought with front wheel assist plowing in Rantoul show, or am i mistaken and was that your 60 ??
Awesome, you are a talented machinist and craftsman!! But I must ask, the 4th picture from the bottom with the gears in it. The larger gear on the right looks like the center is offset which would make it wobble when turning. Is this just an optical illusion from the camera angle??? Chris
I plowed with it at Rantual,,there is only 1 other 2cylinder 4 wheel drive and it is a 730 located in England
