Howdy Y'all and Happy Holidays
Having a problem with the 2N and wanted to run some ideas by you for comment.
'46 6v pos ground - after plowing snow for 60 minutes or so, the engine will falter, like running out of gas. A quick pull on the choke will get her to recover RPMs but it will happen again. I assumed it was a spark issue since making the mix richer restores the RPMs. Once when it happened I pulled the fuel bowl off and drained it in case it was water in the fuel. When I restarted, it ran great, for about 5 minutes. Now I am thinking it is something electrical getting hot and in doing so it is limiting the sparks. The time it took to pull the fuel bowl and replace it let it cool down enough to run well again, but whatever part was warm got too warm again.
Coil? Maybe, but if that was the case it would take hours to restart the tractor.
Ignition Switch? Maybe, will have to get a jumper wire put together to test it.
Condensor and Points? Could be as well.
Spark Plugs? I don't know, they start her well so I think they are okay.
So, any thoughts? I think I will start with a jumper wire and go from there.
What do you think?
What do you think?
