Hi, I purchased a running 60. The tractor I assumed had a bad oil pressure gauge, so I stuck a working one on it. The old oil pressure fuel shut off had been eliminated. After changing the oil pressure gauge, still had no reading. Removed the line and oil would pour oil the fitting but not shoot out as it would with no line. Tractor runs fine, removed the valve cover rockers are oiling as should. Question is why no pressure to the gauge? Oil pump is turning, screen is clean, no breaks in the line to the gauge.. am I getting sufficient pressure to the other working parts? (mains, etc.) Adjusting the pressure screw on the side did nothing to increase..It doesn't make any noises like there was no pressure (knocking). Is the a way to check the other oiling lines? remove them and see what comes out of the lines going to the mains at cranking speed? Ideas?
