60 rod bearing
WiRusty
Trying to bring a 60 back to life, clevite rod bearings stamped 6 65 CB 468M. Wondering if they are standard or over size. Asked a couple parts stores, Deere, YT parts. Nobody has that number listed. Any ideas where to ask? Thanks
Mike the crank. Or find a parts man with a bearing mike. Look for the specs for maximum thickness at crown. Not many will know what the he!! I am talking about. Those look like inserts from 1965 so they may be std, but by now the crank is worn to where .002 or .003 may go in or the crank needs grinding.
6 65 is date. CB is connecting rod bearing.
Don't know about 468M, but undersized would be marked.
Also standard are usually marked. I would guess they are standard.
If you found the clevite # on the bearing shell, look above the number on the right side. The set I have is stamped "std" there. It should be marked std, .010, .020 indicating the size. Obviously it is best to mike the crank for size and out of round if you want to do it right the 1st time.
