60 upper water pipe seals
820Art
My 60 is leaking coolant at the upper water pipe seals where the pipe joins into the castings. Is there just an o-ring in there? Does anyone know the size off hand? Also looking for a brake pedal for a left hand side of a 60 high seat standard. Part number is AA6185R
A very good chance the pipe has a pin hole.
I lube the new orings with silicone sealer. It makes them slip together pretty easy and will harden to seal up any imperfections.
New water pipes are available at Sharps Antique Tractor Works (http://www.external_link.com)for $30.
I got one for my 60 a few years ago. I beveled the ends slightly to reduce chances of cutting new o-rings. Use a lubricant during assembly. O-rings are from john Deere.
Larry
