600 Oil Pressure
RDobbs
Have owned the 600 for 30 yrs and oil pressure has always
held a steady 40 lbs.
Recently the oil pressure will start out at 20 lbs then maybe go
to 60 then after about 5 mins settle back to 40 lbs and hold.
Does this sound like oil pump going out? Oil level is full.
If what Shaun said doesn't help, then I would look at the pressure relief valve and spring. Assuming the gauge isn't at fault, I don't think a failing oil pump would go to 60 psi.
