601 Workmaster loader
FSA1953
Try to find if they made a bigger bucket than the one that's on my machine it's about 36 wide.I was told it's that size to load coal wagons. I'd like to get a larger one if possible or possibly put on the quick attach so I couldn't swap to whatever I need.
601 is a series of tractor. There are a number of sub models of the 601 series. There is a good many loader which could be mounted on a 601 series Ford. Dearborn is one which is Ford's brand of loader or a Wagner brand loader. Hard for us to be able to help you help your self with out more info
I went back and looked at your pictures, that loader looks like a Ford 19-97 or 19-105 series 703 loader. The 19-97 had double-acting lift cylinders and the 19-105 single-acting. Anyway there were several different buckets available. The one I have is 5 ft wide and is probably the most common. Finding a used 5 ft bucket in good shape separate from the loader might be problematic though.
Here's a picture of my 5 ft bucket next to a TLB with a 7 ft bucket. Also a manual cover that shows the narrow bucket.
<img SRC =https://i.postimg.cc/LXQg632N/455-D-713resized.jpg>
<img SRC =https://i.postimg.cc/3NVScyPQ/703-Loader8-Na.jpg>
Here's the loader on my tractor. I was asking if they made a bigger bucket.
As mentioned you may have a difficult time finding one with the correct pin spacing but with some work you can replace that one. Watch online for a used one then just modify it to fit the width of your frame. You can cut the brackets off your existing bucket and reuse them.
