6030 Fenders
WTC
I have a ROPS to put on a 6030. Are the fenders the same except for the hole for post to go through (different part numbers)? If they are the same, does anyone have any measurements of where to cut the holes? Thanks in advance for any help.
When I put ROPS on a JD 4520, I made some brackets and bolted the fenders to the ROPS posts. Not original but it looked pretty good.
6030 fenders are a bit unique, but the 4320/4520 fenders are very close and will still work fine. You might even want to cut the toe notch into those, which will allows the battery box lid to be lifted off a bit easier. As for mounting the fenders, I have done it both ways. Mounting to the outside gives you a little more room on the platform and flexibity in how high or low you want them to be. I have taken the roll-bar to a machine shop and had mounting holes drilled into it. On the flip-side, I have also neatly cut the rectangles into the fenders and slid them over the roll-bar to look more original. If I get time tomorrow, I'll measure the cuts and post them.
