611B Battery Tray
deano1111
Ok, I give, how do you get the battery tray out. I see no screws looking down on top of the tray. I did find a spring at Fastenal. Trying to fish that spring up to hook that cotter pin has ate up a lot of time so far. Very tight in that area as you all know. Thanks for any advice,
Deano
I see them! Wow. Thank you Case Nutty 1660. Probably been in there since day one. Going to be a challenge. Let the games begin. Thanks again.
Deano
Well; personally, I would find a long el-cheapo screw driver and grind a V notch in the end of it, perhaps bend the shank a bit if needed and hook it to the end of the spring that goes into the cotter key and push it up to the cotter and twist and turn cotter key to hook it in. Might take two people.
Loren
ACG, Good idea. I've been using long needle nose plyers. I'll try the screwdriver idea. Thanks. I sure appreciate it!
Got it!!! Thanks all!
