620 Bearings
NY 620
I am looking to try to cross-reference the bearings in my transmission, so I can try to find the bearings at a distributer if I can. I have used the “JD2cylservice.com” to try to cross them and I got a few crossed but not all of them. Can someone tell me if there is another site to try to cross-reference, the John Deere part numbers to another bearing manufactures part number. I am looking to cross-reference John Deere part numbers JD 7764, AA 6619R, JD 7649, JD8199, JD 7937, JD 8198. I am looking for all of the bearings in the transmission to replace them and would like to have them on hand before I tear everything apart. Also if there are any tricks to replacing all of the bearings in the transmission it would be appreciated if they were passed along since I have not done a John Deere transmission before. Also if someone has the dimensions of the ball on the shifting lever because I believe mine is out of spec.
Thanks
register on john deere's website and go to the parts section where you can type in the part number and it will bring up a drawing with dimensions of the part. i just overhaulled the transmission in my 60 and used it extensively to find dimensions of parts and bearings. www.applied.com has decent prices on bearings and there might be one in your area.
Give your bearing supplier the JD numbers, they should be able to cross them. Kaman in Syracuse does.
not that big a job, & only takes about a grand or 1200 for cash. cheaper than your buicks tranny. Its 50 years old, heavy duty & made to be abused. not bad for what you get out of it.
