620 getting engine oil in rearend
Dusty770
the only was engine oil can get to the rearend is through the reduction gear cover correct through the clutch pully seal and main bearing? its going through about a gallon a day. thanks Dusty
Yes that about it..
Unless someone else is draining from the crank
case & dumping it in the trans..
Main seal needs replaced & bearings need checked.
On a 60 there is a plug,kinda like a freeze plug,part number 3256, that will let a lot of oil in from the transmission if its not seated, found out the hard way
On a 620 or 630, IF the Clutch-side Crankcase Seal is leaking..Measure the clearance on that Main Bearing...
There is a very good chance the bearing (AND Rod) are Starved of Oil pressure..
The cause is a small circular "Seal" ("O-Ring" that can swell and Block the oil flow..
If you need to replace that seal (and Main Bearing..?), put a short, threaded Brass tube in place..(the threads are already there) that is long enough to keep that "O-Ring" from moving and blocking the oil passage..
This "O-Ring" is between the Main Bearing Quill and the engine Block..
If the Main Bearing is bad (excessive clearance..that Rod bearing probably is bad, too..
Ron..
