620 won't move
I was driving in 3rd gear, stopped to put it in 2nd to mow, when I let the clutch out in 2nd gear the tractor wouldn't move. I can't get the shifter to move into any other gear, it will move left to right into and out of 2nd but won't move forward to go into 1st or reverse. help :cry:
The lever has jumped out of the forks. You will
need to lift the shift quadrant, put the forks where
they need to be, and put the lever appropriately.
I would consider replacing the lever and ball
assembly- it's probably worn enough to let this all
happen.
