6200 Hydraulic Pump Question
XL cid A
Can anyone tell me how to tell the difference in the hyd pumps
on a 6200? There's a 20cm and 40cm John Deere doesn't say
that if ones marked with a certain # so is there any other way
to tell the difference or what do you go buy??
Thanks if anyone knows and can help
We just got a 6200 a couple months ago that JD told me has the higher output pump. I will get some pictures for you later on when I'm over at the shed.
One way to tell if you have the higher capacity I found out is you will have a filter that is larger capacity by the right rear under the cab. Sorry pictures aren't great!
