Matthew Blevins
This guy I know has a problem with the tractor jerking in the rear end at a certain point of rotation. It is a 2000 4 cyl. diesel with 8 speed I haven't drove it, but the way he describes it, it sounds like a tooth missing on a gear somewhere. He said it is like it looses momentum at a certain point, then catches, being real ruff in all gears but 4th gear being the worst. He says it has a two speed lever under the seat. So I am guessing it is a rear mounted auxillary transmission. I remember some of you guys talking about a transmission of this sort, that you couldn't get parts for. I can't remember if it was a Hupp trans or what. Question is, what would be needed to take it out, if it is the problem or what could the problem be? Thanks
