'63 super dexta input shaft seal
Goose724
I've identified that my input shaft seal is leaking (gear oil out of the weep hole on the bell housing) and i'm trying to figure out what i need before i split my tractor.
mine's equipped with a live PTO.
what will i need to replace? is there anything unrelated that i should replace when i split the tractor just because? (clutch behaves perfectly healthily.)
TIA.
i'm trying to order the input shaft seal but i've got a bunch of results here.
does anyone know the exact part number for the input shaft seal? i'd rather not buy the wrong part.
Here is what I offer:
absolutely wonderful, thank you so much.
do you know if there are any other seals i should do when i split my tractor at the bell housing?
i'm trying to stop a gear oil leak that i've verified to be coming from the weep hole.
Rear Crankshaft seal https://www.yesterdaystractors.com/Ford-Super-Dexta_Crankshaft-Seal-Rear-Rope-Type_735866M1.html
