630 Brake Drum
edinmo
How difficult is it to remove the brake drum while the brake assembly is still on the tractor. Can you get it off with a 9 or 10 inch gear puller? I need to install new brake linings and would prefer not to pull the entire assembly off the tractor.
If the brake drum moves on its splines, its off. Use a puller if you have room. Or take off the drum nut, take out the washer and lock washer, put nut back on shaft, and hit nut with a hammer.
I have removed the brake drum without using a puller. You would probably need to back the adjuster out to give clearance. I have learned that it works better for me to remove the entire assembly from the tractor. Three bolts and maybe an axle stud. That allows me clean, inspect and repair the whole assembly while clamped in my bench vise.
