630-power steering
730-TOM
Friend asked me this morning if it was possible for the power steering fluid to get in with the engine oil. his is low but no visible leaks. after sitting all winter, he says that the engine oil is up a little from where it is normally. Does not smell like gas. I don't have a power steering manual so I really didn't know.Thanks for any info.
My 60 is doing the same thing. I think the power steering pump seal leaks and lets oil run down the fan shaft tube into the governor housing and then into the engine. I'm no expert, but that is what I have been told. When i get time I will find out.
yes the power steering fluid can get in the engine oil. it can leak past the seals on the power steering pump and then down the fan shaft (this is what drives the power steering pump) then into the governor houseing and then down into the crankcase. i would recomend resealing the power steering pump. good luck with repairs i hope you get it fix up.
The guys are correct, and you'll need to know that the original chevron seals were longer ago changed to two single seals in the front and two of the same in the back, sitting face to face. They also call out a spacer washer between one pair of seals. Some folks say they can't get it to fit using the spacer, but I've always got it in there just fine.
The seal pairs are oriented face to face so that they seal out engine oil from the fanshaft to the pump and seal in power steering oil on the rear pump side. The front pair seal power steering oil in and air out. You can see the arrangement and the part numbers in the 520 tractor parts book, which was the only book that ever got the updates on those parts. You can view and download that for free at jdparts.com
