638 round baler
Hi I got a 638 round baler that acts like
the bale chamber doesn't want to expand
after it gets about half a bale then
starts puking it out on top the pickup
any ideas
Might have to up your ground speed to get enough material to start a bale. Sometimes in real fine dry hay my NH baler will throw it out the front till it starts to roll. Might work better if the dew is on the hay yet.
(quoted from post at 17:42:47 06/08/20) Hi I got a 638 round baler that acts like
any ideas
If you are getting half a bale, you have started a bale, if there was something stopping the movement inside, the baler would likely keep eating hay and break a shear pin. There is only the one roller connected to the springs on the side that moves, but this all moves when you open the tailgate, so I'd think anything jamming would be evident.
If you eject the bale just as it "pukes out" is the bale formed, or just a pile of hay?
I run a 630 and if the hay is too dry or really short it doesn't want to start a bale easy and makes a mess, lower PTO RPM and stay in same gear and often it will start a bale easy.
This is interesting- my 4590 M&W chain baler did that on 2 bales on me. The chamber was mostly full both times, but I was on a hillside and was in a lower gear than I normally run. I could only attribute it to the short, fine hay that was mixed in with the taller stuff and ground speed. I had to lay under the baler and pull the hay out by hand. You are in Ohio, and I am in northern Kentucky, so maybe the short hay this year has something to do with it(we had a cold spring). Or, something else is wrong with your baler. Mark.
