64 4000 5 speed question
Hi, my first post but have learned alot being a member.
1964 4000 5 speed, gas,
The specs. For transmission fluid show 8 quarts - 2 gallons. My question is do I only put in 2 gallons or fill transmission until fluid leaks from plug on lower side of transmission?
Also side note stamped on side is
4102 S/N 3928 '1
What does that serial number mean with the apostrophe? When was it built?
Thanks,
Richard
4102 S/N 3928 '1
Thanks,
Richard
Are you sure about those numers? The serial number should not have an apostrophe but 39281 is a valid serial number for January 1964.
4102 is the start of a valid model number, 4 means 4000-series with 172 engine and 1 means 1963 or later. 0 is not a valid third digit but 20 (third and fourth) would be meaning All-Purpose four wheel model with adjustuble front axle (agricultural model). There should be a fifth digit indicating transmission, PTO, and sometimes hydraulics, since you have a 5-speed 2 would mean 5-speed with live PTO.
Thanks that is what I did. 4 gallons total. Seems odd hold twice as much as what is specd
The memory is fading i forgot to put 2 on in. 41202 is correct model. I just noticed multiple ' marks perhaps shift? Day of week I don't know
