(quoted from post at 20:24:49 12/16/23) JD Dave, enlighten me is this draw inside a starter caused by metal dust something specific to a JD with the 24 volt system due to the cable connection from the battery direct to the side of the starter? I could possibly see this as happening. In most Delco starters the circuit is broken in the positive engagement solenoid when the solenoid is not being energized by the key switch during starting. The high amp starting circuit is then open so it cannot have a draw. I have never heard of any draw found in one of those circuits on these types of Delco solenoids.
To Hayward, you will need to disconnect a cable from each battery and test for the ..parasitic draw.. with your meter in a series through the disconnected cables, each battery will need its own test. In other words one lead on the post and one on the disconnected cable post clamp. The 12 volt loads are balanced on those tractors taking approximately half the load off of each battery, this includes the lights with the switch having separate circuits for each battery.
If you find a draw I would suggest first pulling the voltage regulator cover off and look at the contacts for the three sets of magnetic coils. Lightly pull on them with your finger nail to see if one pops off its contact and then stays off. If you find this, that is where your draw is from. You may be able to clean the contact with some fine grit emory cloth and get it to work. Most likely it will require replacement. I know in many other cases for these old generator systems it is hard to find a quality replacement that lasts. If I am looking it up correctly a JD regulator is $115, probably well worth the money if it lasts 5 years or more.
I am attaching an old YT post that includes a wiring diagram. The in the original diagram the circuits are identified by left or right battery by a dashed line either above or below the circuit. The copy in the post is not good enough for consistent ID of the circuits in this way.
YT post with early 3020 24V wiring diagram
