6400 mfwd pivot pins
boner58
I am looking to purchase a 6400 with mfwd. the only major issue is that the pivot pin on the back side of the front axle is majorly worn, I figure at the point its worn I will have to get a different axle housing as I can see its about worn through. I cannot seem to find the pins that go on the actual tractor though. are they replaceable? or would you have to get a new frame?
I found them on jdparts.com, look up the front axle then page ahead, need to know your serial no. and whether the retaining bolts thread into the pins or have nuts to retain them.
