Alpine Cheesehead
I just got this tractor. I adjusted valve clearance to .017 cold, all new wiring, new 12v coil, cleaned carb, new belts, fresh coolant, oil/filter change and new alternator.
When I first got it it seemed to have a fair amount of blow by. I checked compression and I have 120ish in all cylinders cold and dry and 125ish with some oil in the heads so I think my rings are okay. A few valves were a couple thousands off. I was hopeful the valve adjustment would fix the problem.
As soon as I touch the starter button she starts and sounds great. It seems to run great at all RPM's.
I am still getting a lot of blow by from the valve cover vent and oil fill vent. Maybe even more than before. Even after the motor is off it continues to smoke from the valve cover for a while. I took the valve cover off while it was still hot and there is smoke/steam coming from push rod holes. Also I noticed 2 small spots of white/oil spots on roof of the valve cover above number 1 and 2 cylinders.
When I changed oil I did not notice any milky oil. Also the tail pipe is running clear.
What do I have going on? Head gasket??
Jason
Jason
