641 ford aux transmission
chris hamby
hello folks i need some advise on what action i need to take . i have been researching hupp and sherman step up step down aux transmissions , i need direction on what i should buy i am needing lower gears in some instances and in between gears at other times especially when turning ground .. do you guys have a preference and what information will i need to know to buy the correct application.my tractor is 641 serial no 57480 has 4 speed trans
The Hubb is a some watt fragile and very hard to find aux trans. The Sherman is pretty common and the one you really want is the combo which is a 3 speed which gives you over drive, the normal gearing of your tractor and under drive. I have one in my 841 and it is nice to be able to go so slow a snail can out run yo but also so fast you will wish that you had never done it. I have been cloaked at 45mph on my 841 and lets just say NEVER ever again
thanks old for the info i am going to delete this post as i finally figured out how to log in with my password so that i will not be logged as visitor thanks again for info
