641 hyd 3pt down force.
Craig 59 641
Question hydraulic s on my 641 should I have the same down force as lifting on 3pt hitch. My back blade usually floats over ground not digging in like I think it should. I rebuilt hyd pump with master kit from yesterdays tractor. It made mud work much better. Just wish I had more down force.
As Royse stated, there is no down force, just gravity. Some folks hang weights on the top of their back blade to give gravity an assist.
As Sean & Royse have said no down pressure. Weights and toplink adjustment about the only options. The older back blade and box blade were made of heavier steel so they dug in better. Not so today, lighter
steel to cheapin them up and that's why you see so many all bent up. Lengthen your toplink and it will dig a little bit more.
Kirk
