Many thanks for this forum. My 641 power assist steering suddenly quit so I had to muscle the steering wheel to guide the tractor about a hundred feet to my shop. I used this forum to guide me through the power steering control valve removal and dis-assembly, where I found one of the three plunger springs was broken. I cleaned all the components, lubricated them, replaced the three springs and the seals with new CNH parts, and reassembled everything being careful to allow for proper amount of torque on the thrust washer. Still no power steering. I noted that, while running, the PS fluid in the reservoir does not roil, even when I gently try to move the steering wheel. My thoughts are as follows. 1. I may have installed the spool wrong, with the ID machined groove up. 2. When the PS originally quit, maybe it was the pump that failed, then maybe I broke the plunger spring when I muscled the steering to the shop. Any insight is greatly appreciated.
