641 STEERING WHEEL REMOVAL
N.L. (MS)
BEEN TRYING TO GET MY STEERING WHEEL OFF, DO THEY MAKE SOME SORT OF PULLER OR ANYONE HAVE A WAY TO GET IT OFF? DESIGN OF TOOL WOULD HELP AND MAYBE I CAN MAKE ONE.
Hi , yes they can be a bear sometimes . Get yourself a steering wheel puller . Once you have it set up & have pressure against it , take a hammer & beat around the base of the steering wheel while pulling toward you . Make sure you have good footing so that when it pops loose you don't fall off the tractor . Its spring loaded so be careful . I've even had to add heat from an accetylene torch to get them off . Let me know how it goes or if ya need more help .God bless, Ken
I removed mine a couple of weeks ago and it took about three days of hitting it with PB Blaster . I also had a three armed puller that just barely caught the lower edge of the hub. The puller didn't have enough grip to horse on so I just left the pressure on it. A hit with the hammer every once in a while and one morning I noticed the pressure was off the puller.
Of course I'm in no hurry and I'm able to work on the tractor in the garage at my leisure much unlike my 8N at camp that's under a blue tarp.
Jack
i got a broken nose pulling steering wheels... but that was when i was about 15 years old and thought i knew everything. 40 years later i got made a homemade puller so i would break the plastic off of the frame on the older steering wheels...
