6410 remote valve flow.
Craig C
I am looking into putting a selector valve on my loader to split
the flow for a grapple. I don't want to choke my system and
slow my cycle speed down. I am sure the remote flow is
considerable less than pump flow. Any one know for sure the
flow specs on a factory installed deere loader valve.
I am not sure I understand your question. You want to add a grapple and run it how? How is your loader plumbed now? Does it use a power beyond and mid mount valve? Deere does offer a mid mount valve with electric activated third function ($) or you could "cheap out" and run your third function from an SCV. Either way flow will not be an issue especially if you have the larger pump.
I have the deere loader on joystick but the valves are on the rear. I don't want the grapple on a rear scv because I don't want to have to take my hand off the joystick. I was looking at using either a selector valve out on the loader boom, or an electro hydraulic valve for true third function. I was asking to see how l large of selector valve I would need. My op manual said up to 25gpm with the large pump. So that puts me needing the larger selector valve. That is probably the simplest way. Does deere offer a power beyond for a 6000 series that already has four remotes on the rear. I would also need a electro-hydraulic pfc valve.
