641D Possible to put a loader on this?
TX641D
Have a 641D. Wanting to know if there are any successful ideas for putting a loader on the Tractor?
Thanks,
Steve
Not sure what you are asking.
The size, shape, wheel base and
attaching points are the same on
all the utility style Hundred
Series, 01 Series and the 4
cylinder Thousand Series - from
1955 till early 1965.
There are many thousands of
these tractors still in service
and a huge number of them are
equipped with front end loaders.
So yes it is possible to add a
loader to your 641.
There were many loaders built
for those models. Some by Ford,
more by aftermarket companies.
Look on Craigslist, the
classifieds on this site, ebay
or other places.
Keep in mind that many of them
have been run hard and are just
plumb worn out. So look a
prospective purchase over
carefully. Take pictures and
post them here. Ask questions
about them as there's a lot of
knowledge here.
I have a one arm loader on mine. works quite well even with no power steering.
<a href="https://imgur.com/08Wv5xy">
08Wv5xyl.jpg" title="source: imgur.com"
</a>
thanks! that's good news.
Where do the hydraulic lines attach if I find a decent one? Sorry...may be a rookie question.
Steve
(quoted from post at 22:48:43 11/13/18) thanks! that's good news.
Steve
You can handle hydraulics three ways, 1 from an after market cover beneath seat to use the present pump (least desiriable plus requires pump and system to be in better condition than required for 3 point) 2 a pump driven off pto shaft (works well but is in the way of attaching 3 point implements ) 3 a pump mounted in front of radiator and driven off front of crankshaft (most popular way).
If you haven't found one by then,after the holidays I'll have a Ford model 703 loader for sale just down the road from you. If you are interested,click email in this post.
if you have a valve on the hyd top cover you are most of the way there, post back what you actually have, so then we can give you specifics.
(quoted from post at 13:37:09 11/15/18) if you have a valve on the hyd top cover you are most of the way there, post back what you actually have, so then we can give you specifics.
tock accessory plate the last time I saw it.
