My 2007 6430 lost all its hydraulics I don't have a way of
testing the pressure but you can see the fluid moving when it's
running there is no steering or hydraulic outlets or 3 point that
works but it drives just fine is there a sensor that could be bad
I see a plug in on top of the valves but not sure looking for
advice fuses are all good
If you have no steering, no remotes and no 3 point you have not got an electrical problem, Do you have P.C. or P.F.C hydraulics?, I am wondering if the drive to the pump has failed?, the transmission has its own pump or if the internal oil pick-up tube has come adrift?
