65 2000 loader
Good evening
Will a ford I9-97 loader fit reasonably well on a 65 model 2110 3cyl? This is a lcg version of a 2000. It has 16 in. on the front and 24s on the back. This loader came off a 860. Thanks for your input,Lowell
That old I9-97 number is not showing up on CNH website. The new mumbering system for loaders which mostly started with 7 - 711, 720, 730, 772,etc would.
If you could post a couple of photos someone here could probably ID it and give you more info.
I do know some loaders were made to fit both the 4 cyl and 3 cyl tractors though with different brackets.
The 3 cyl models were 2 or 3 inches wider than the 4 cyl models so not all of them will.
When you look on the parts site you need to convert the I (capital letter i)to a 1 (number 1). 19-97 shows as being a 703 series Ford Extra Heavy Duty Loader, which was made up through 1971, so there's a chance it would fit a 3 cylinder, but you may need different mounting brackets.
