Bern
- Location
- Mount Vernon, WA
A post a few days back discussed compression pressures on '65 and up Ford diesel engines. The OP was asking if pressures in the high 300s were OK. I maintained that it was, someone else posted some specs from a 5000 repair manual indicating it should be between 420-510 PSI.
Those numbers of 420-510 are flat out wrong. Unless you have a large amount of carbon buildup inside of a cylinder, you'll never see over 400 PSI on a Basildon series diesel ("BSD"). I believe those numbers came from the original testing procedure which was for a test with the engine running. However, at 200 RPM cranking speeds, you'll never see 400 PSI, let alone 500 PSI.
In the interest of not having someone rip apart their engine for no reason, I have included some information above taken from a manual Ford put together back in 1987 titled "Diesel Engine Diagnosis". It was specifically for the Basildon series diesels only. Note that they're looking for 290 PSI minimum for non-turboed engines, and 275 PSI for turboed engines.
Also, specs from a TW repair manual (same engine family) show compression pressures of 325 PSI for a turboed engine, and 350 for a non-turboed engine. In my extensive experience compression testing numerous Ford engines, those numbers are pretty close to the mark.
Hope this helps.
Hope this helps.
