656 Hyd Remote Valve
cool hand
Location
SE IN
Farmall 656: Single remote hydraulic valve leaking oil badly. Is there a cure available. It appears that parts from Case/IH are no longer available.
All O-rings that would cause it to leak externally are available at CASEIH. If you mean it won't hold a load up that is a different story.
Most likely the problem is the O-ring is worn out on the unlatching piston, #396582R1.
The piston is item # 8. You will also need O-rings 9, 14, and17.
