660 vs 640 JD Hay Rake
Navajo350
Any one know the difference between a JD 640 and a 660 hay rake, besides one having a front wheel? Also, is the front wheel better for operation or storage?
Thanks,
Robert
With the front wheel - forget about backing up, but then how much backing up would you be doing with a hay rake?
I think mine is a 660 (can't remember the number) - it has the dolly wheel. I really like it. I'm pretty sure it will turn sharper than one without the dolly wheel.
I also like the dolly wheel for getting it into the shed. I can back it (by hand) through a doorway that is less than 10' wide by putting a corner at a time in. The rake is wider than 10'.
Make sure you get the driveshaft with it. One of the u-joint yokes is proprietary and I'm told pretty expensive. Also - remove the driveshaft when roading it.
Most 640's were only four bar. The fifth was an option. All 660's have 5 bars. The lift set up is a little different but not any better. All gear box, drive and bar parts are the same. We took a 640 and completly rebuilt it. We replaced every bearing in the whole rake and added the 5th bar. We also added extra teeth to all the bars. Tom
(quoted from post at 09:31:32 10/05/17) Any one know the difference between a JD 640 and a 660 hay rake, besides one having a front wheel? Also, is the front wheel better for operation or storage?
Thanks,
Robert
Both 640 & 660 could have the option of a frt gauge wheel.
