6600 gearbox noise
gerard
Bought a 6600 with Schindler FWA a few years ago. Gearbox was always noisy - lots of clatter - put it down to having a cab & being a Ford (my MF 135 gearbox is silent).
Today, a new noise started - a high pitched screech proportional to revs / road speed. Barely noticeable in 1st & 2nd, but quite loud in 3rd & 4th above about 1,000 rpm (DP in high or low). Pitch is about same as an air drill. Not a whine - more of a screech - bit like a bearing at high speed running dry. Seems to come from gearbox area.
Any ideas what I should be looking for? Everything"s working fine, but this noise concerns me.
Gerard.
I'm just thinking out loud...but if you put the back axle in the air and take the top cover off of the transmission ( not so much work ) you can let it spinn and you can watch and locate the problem ?
be sure to have it on some decent (wooden) blocks before you let it spinn.
Roel.
