6610 plowing
David G
I am planning to plow with 6610 and 3 bottom mounted plow this weekend. I have never used draft control and want to try it. Do I use position control, then switch to draft?
Thanks,
David,
You can put it in draft control from the start. You do not need to switch back and forth.
You will also want to make sure you attach the top link in the bottom hole of the tractor.
Then adjust the stop on the quardrant to set your depth.
HTH
Keith
