'67 Oliver 550
Wayne Six
Parked tractor last weekend and when went to fire it up today I had a puddle of oil under it. Looks like the brake pedal cross shaft seal has let loose on the left side and right side is weeping a bit. Does not look like YTC carries them, but have ask. Found a forum comment about how they can be picked up anywhere and I suspect that is true IF I know the bore size, inner diameter and thickness. Can learn all that when I pull them out, but would sure like to have them in hand so that I can replace them as soon as I get the old ones out. Anyone know where to get the seals, or their dimensions? Oliver part number is 1E-930 if that helps anyone...thanks for any leads.
