robertd
my hydro fluid is pumping from the trans in to the rear end half were the 3 point lift works but is returning it back to the trans . AAfter 5 min my fuild is gone and quits pulling. please help 502.712.9381 robert
I will asume that you mean that the transmission oil is being pumped into the hydraulic sump.
Remove the side inspection cover (after first draining the oil down partially). With the transmission refilled and the engine running use a flashlight and mirror if necessary to see where the oil is escaping into the hydraulic sump.
It could be the pressure switch.
Dean
thanks alot dean for your help. I cant see were it is leaking from. but i was asuming that the pump on the side of the motor pumps hydro fuild from the trans sump to the sump in the rearend were the lift goes for the 3 point . and then it would return the fluid to the trans sump some how. but it is keeps pumping fuild from the tran in to the rear hyro sump. it will empty it in about 5 min and will not return to the trans sump
please call me I can explian my name is robert 502.712.9381
Robert, no need to call so you can explain. Your transmission system is totally separate from your hydrualics. The pump on the side of the engine has nothing to do with the transmission. The transmission pump is mounted on the transmission input shaft inside the bell housing and serves the transmission only.
Do as Dean suggested. There is a leak on the back end of your transmission soemwhere that allows the transmission oil to escape. You need to diagnose the leak and repair it.
