Not even close to what the OP is asking about.This Elring head gasket set is available for purchase in Germany.
ELRING Zylinderkopfdichtsatz - IHC (3136799R98, 3136799R99) 1967014C1, 1967014C2, 1967014C3, 3136799R98, 3136799R99Motor , Schlepperteile, Traktorteile, Ersatzteile
ELRING Zylinderkopfdichtsatz - IHC (3136799R98, 3136799R99)1967014C1, 1967014C2, 1967014C3, 3136799R98, 3136799R99Ersatzteile, Neuteile, Motorüberholung, Zylinderkopf, Motorblock, Shortblock, Krümmer, Schalldämpfer, Einspritzdüsenwww.schlepper-teile.de
How so? German gaskets for a German engine, might be the best you can get.Not even close to what the OP is asking about.
Yeah I kinda figured that, usually talking about the 74,84,85 series it’s referred to as a D239Ur right. I was looking at the 239 engine. Such as in the 460.
If you don’t mind answering, why are you replacing the head gasket?thanks for the help, got one ordered hopefully get it replaced in the next couple days
A 239 in what 460?
No, an IH 674 diesel. Read gstouts first post.I've got a ih 674 diesel with the 239 engine, what would be the preferred brand of headgasket for replacememnt ?
I think Fritz was questioning rr reply, he had the wrong CID. The 460 Farmall and IH utilities had a D-236.No, an IH 674 diesel. Read gstouts first post.
A 239 in what 460?
Well, I just had to be sure, elsewhere I stated that there was no way a 53 series Detroit primary lube filtration was by-pass, yet there it is in black and white Deere specs. I thought there must be some 460 out there i hadn't heard about.I think Fritz was questioning rr reply, he had the wrong CID. The 460 Farmall and IH utilities had a D-236.
CNHI IH D-236 parts catalog
Case and deere both farmed out old tractor parts to a&I nearly 20 years ago.KR’s giving you the part numbers there, you can get the CaseIH set for around $350 or you can get the A&I set for $60. I’ve used both and didnt see any real difference, might even be the same
D-236 six was used in the IH 460.Ur right. I was looking at the 239 engine. Such as in the 460.
