674 hyd problems
boltcuter
I have a 674 International with no hydraulics
The drive gear behind the clutch spins on the
shaft.My question is can it be removed without
breaking the tractor in half.
Hi Boltcuter, are you saying the PTO shaft is spinning in the pressure plate? The PTO shaft is the outer splined shaft that is driven by the pressure plate. Often if the tractor was used for heavy PTO or hydraulic use the teeth on the pressure plate get stripped.
To do clutch, pressure plate and bearings requires a split at the bell housing.
JimB
