'68 Ford 2000 overheating
drsevy
68 gas 2000 overheats after about 15-20 minutes of running. Idles fine, no coolant leaks, no oil in radiator or coolant in oil.
Here"s what I"ve done:
1. Replaced thermostat
2. Flushed radiator
Top radiator hose gets very hot. Bottom radiator hose not hot. Top of radiator hot.
No fluid comes out of petcock when unscrewed.
Fan belt seems tensioned fine. Fan blows
Don"t see any water circulating when radiator cap is removed
Is it time for a new water pump, radiator or both ? Any way to test water pump.
Thanks
I have to ask the embarrassing Q: did you put the thermostat in backwards?
(Assuming you did it correctly...) the radiator core may be clogged and it pretty much takes a pro-boil out to fix or it is the WP. WP's are pretty cheap, and a carry in boil out is also reasonable. I would go that way. Some here (I think "old") have had real good luck putting in a strong solution of vinegar to get the crud loose and out. Maybe a search of "radiator cleaning" will turn up more hints/tips.
jb
having the top of the rad hot and the bottom cool is normal. Coolant enters the top and exits the bottom, being cooled by the air side as it passes downward and then to the pump.
Is your radiator cap functioning properly? Look to see if the hose collapses at high rpms. Did you put the thermostat in correctly. You say you don't see water circulating with the cap off.That's usually the best way to test the pump. The usual failure mode is the seal and bearings failing.
Is the timing right and the carb mixture correct if it's gas and is the air cleaner clean if it's a diesel?
Have you tried blowing out the air side of the radiator. A lot of dirt and chaff can clog the air side.
Drsevy;
You should definately see the water circulating in the tank. If you do not, then there is a restriction somewhere. As was mentioned it could be a water pump failure. The impeller could have broken. As John_Bud said, make sure the thermostat is installed correctly. Water not coming out the drain indicates a sediment build up which is not unusual. Remove the drain petcock and insert a punch in the hole to see if it can be cleared. As was suggested, have the radiator boiled and rodded out. While the radiator is off check the pump.
Here's some other things to consider.
When was the last time the block was flushed? A lot of gunk can build up in the block. When you run the tractor and it heats up, use a meat thermometer to check the temp in the radiator to confirm your gauge has not gone bad.
Is your distributor spark advance working properly? Have you checked the hoses to see if they collapse during operation? Drain the oil from the engine and check for water in the oil. If there is water in the oil remove the spark plugs and check for water at the plug holes. With the engine cold, fill the radiator to the top. Remove the belt so the water pump will not work. Run the engine at fast idle for 60 seconds. If water runs out of the radiator filler pipe or overflow, or if bubbles come to the surface in the radiator, leakage exists between one or more of the cylinders and the cooling system. It could be a blown head gasket or a leak has developed between a cylinder sleeve and block.
If you have leakage, check the head bolts for proper torque. If none appear loose, remove the head and inspect for a bad head gasket. Look for cracks in the head in the area of the valve ports. If ok, replace the head gasket and re-torque the head to 65-70 ft lbs. Warm up the engine and then re-torque the head. If your engine was rebuilt and they did not re-torque the head, if may cause a leak.
While the head is off, inspect the water jackets of the block and head for lime deposits that restrict flow. Hope this helps. Post back with what you find.
