7' vs 9' Sickle Bar Mower
Anonymous-0
Hi, I'm looking at buying a pull type sickle mower to mow along my gravel road ditches. The ones I have looked at are an 1100 Case Ih with 9' bar $1,000-needs a hydraulic cylinder. A 455 New Holland with 7' bar $850 and a 450 John Deere with a 7' bar $900. I am wondering if there is any disadvantages of a 9' bar? Any comments would be appreciated!
Thank You,
Jacob
For mowing roadside ditches I'd want a shorter bar. For around my road a seven foot is too long.
Go for the 9. I have had seveal 7's, and several 9's. Pull type and three point. The pull type can get pretty trick backing up.
The reasons you want a 9 are: You can mow from the road down a steep bank further, then get in the ditch and reach up to where you cut from the road. You can stay away from those sidehill adventures. You might also find some other hay mowing to do and the 9 will seem pretty SHORT!
I have a huge yard that I was spending a lot of time and money on a 50 inch rider. I did some landscaping and reduced the "yard by about an acre. I let that acre go until early July, then mow with the 9 and bale it. After July I knock it down every 10 days with the 9 on a SH and it takes about 40 minuters to do the job. Believe you me, there's a whole lotta difference between 50 inches and 108 inches. Size DOES matter!
