702 Ford Front Blade
Greg1959
Will a 702 Ford Front Blade fit up and not do damage to my 860 tractor? I can fabricate any brackets needed.
Parts book says 1972 to sometime in the 90s so likely not. But with a torch and a welder...
I wouldn't bother unless it was at least 6' though.
I'm not sure how you'd fit the brackets.
Might be doable with a closer look though.
Assuming you have have external hydraulics to run it.
I have a 7 foot fisher plow on my 63 4000 that originally was on a 73 F250 then I had it on my 78 F150 for about 10 years. So if you have the tools and material to work with many things can be done.
Mark
Looks like you will have to do quite a bit of fabrication to make the brackets. I might have one for sale for your tractor. Easiler and faster to just bolt right on. If you are getting that one really cheap or next to nothing it might be worth the time and material. But than as stated you with still need a valve to run it.
Kirk
