I have replaced the torque limiter on my 7040. Replaced all parts including the ring gear. Tractor runs fine and have used it to back blade my driveway. I now want to use it for plowing. I have not done the break in sequence as of yet.According to the manual it seems quite simple. After all the time and money I put into it,I don't want to screw it up by making a mistake now.It calls for 2000 rpm in a lower gear and then hard braking until engine dies.Then repeat procedure.Why would the engine necessarily die? Are you to apply brakes without using the clutch? Seems like i'm missing something. All help would be appreciated. Thanks Dan
