706 3 point sway blocks
Do they make sway blocks for a 706 with three point
so the lift arms don"t sway so much? If so where can
someone get them?
Matt
Matt, If you go to Case/IH ON LINE PARTS LOOK UP FOR 706 AND 3 PT HITCH you will see bracket and adjustable links that were probably on tractor when new that would stabilize side to side swing.If those parts are missing on yours maybe you could find used. A lot of parts are NLA if ordering all new and even if all were available it would cost a fortune to buy all the pieces new. If you think this is what you need and don't have them let me know and may be able to give help on finding used parts. Bill
No, they do not make sway blocks.
BillOHIO is correct, there should be a sway linkage, but it only has limited effectiveness. The hitch still sways a lot more than more modern systems.
