706 Adding Remote
What is involved in adding an extra set of rear remotes to a 706? Mine only has one set of remotes, and I'd like to add another.
Thanks, Cmore
Not a bad job, just need the extra parts for levers and lines plus make sure the valve you get is open both sides unless your present valve has an end cover plate on it. Some valves are closed on the outside so if your is you would be moving that one to the outer and different on would go inside like your single valve is now. And, only torque the three bolts holding valves on to 20 ft pounds, evenly.
