706 axle bearing?
Farmall 656
Location
Wykoff, MN
This weekend I got my 706 out of winter storage for the season. As I was driving it out of the shed, I began to hear a pop sound and after investigation, it sounds like it is coming from the end
cap area at the end of the axle. It would make the pop sound every 1/3 to 1/2 rotation but didn't make the sound when turning left or right. I have not had time to tear into it, but can I assume it
is the wheel bearing or is there something else I am not thinking about? Thank you in advance for your experience and advice!!
Yup look at the cast center to the axle then the rim to cast. I've not had trouble with the rims bolts though I have had the ones at the axle in the casting work some. Might also look for a crack from one of the square corners in the center casting outward. I had one crack once was plowing and went over a pile of manure the wheel spun free than hit dirt and made a sudden stop of the wheel rotation. That is when it cracked.
Well if you find that after all the checking everyone gave you , do this make darn sure your park lock is ALL the way UP . Due to ware sometimes the park loc pawl does not come all the way our and can cause a noise that was not there yesterday. . More then likely yours does not have the NEW spring loaded park loc., Any 06-66 that has come thru my shop does not leave till a spring loaded park loc is installed . Those are either IN or OUT and NO run away tractors that i have seen several times with the old over center park loc.
Thank you tractor vet!! I will have to check the park lock. I don't believe I had the park lock on when I had it stored in the shed over winter but I can imagine on the 706 it might have met its life expectancy by now. Can I presume I can get the new spring loaded park lock from my local CaseIH dealer? Thanks again...I always appreciate your insight and experience on these tractors!!
